For the pipe resizing "tool" (which is an awesome feature by the way), I was trying to go back to my existing drainage area and run that procedure, but the 'Resizing' tab doesn't show up under the calculation settings.
I do have another diagram with a post-developed drainage area going to a BMP facility with other defined outlets, which eventually flows into a swale. Basically, I just put in a guesstimate for the post-developed pipe outlet size, figuring I could use the resizing feature to double check and possibly change.
Is the 'Resizing' tab not showing up since I in essence defined a pipe size on the post-developed diagram?
THANKS!!!
THANKS!!!
