How is shear calculated on a circular pipe (column or beam)? I have one reference(Design Manual for Structural Tubing -1974) that says to use half the gross section - I am assuming gross area. This is shear across the member,not torsional shear. Why use half the gross section? Is there a shear stress distibution problem. maybe the pipe wall will bend before it pipe shears. Are ther any values for pvc pipe?
