samond
- Jun 26, 2013
- 9
Can someone tell me if there is a difference between stiffness and rigidity of a pipe? I understand that pipe stiffness is used to describe the load vs deflection relationship. We are planning on sliplining an 18" pipe inside an existing 48" pipe and have it "float" via grout to the crown of the top of pipe for approximately 5,000 LF. I will have a simply supported pipe, for lack of a better term, spanning between 400 to 600 feet from manhole to manhole. Skids or some sort of support will be located at each manhole to keep the pipe at the crown of the pipe. There will not be any weight bearing from backfill on the pipe to cause deflection, so I am not sure if I need to compare stiffness specifications. If not, I am not sure what the correct property is that I need to compare to see which pipe would sag the least in the large of a span. I am considering Hobas, polyethelene, and any other that may be suggested. I know that PE pipe is very flexible so I am concerned that grout may get between the crown of the 48" pipe and new sliplined pipe and create a major sag. In any case, I want to make sure I am asking the right questions and exhuasting all possibilities.
Thanks in advance for any advice.
