NewENG102
Industrial
- Dec 17, 2015
- 15
Hi, I am working on calculating what the end load / nozzle load would be and I coming up with a really high number.
Based on a 25' pipe and change in temp of 50F this would calculate to about 1/8" thermal growth.
Below is how I came up with the end load. Would be great if someone can chime in.
Pipe length = 25'
Pipe OD do= 36"
Pipe ID di= 35.25"
Pipe Cross section area A ((pi*do^2-di^2)/2) = 41.97 in^2
Modulus of Elasticity E = 29500000 psi
Change in temp dT = 50 F
Coefficient of thermal expansion e = .00000633 in/in-F
Stress S = E*dT*e = 9336.75 psi
Force on Nozzle / End Load S*A = 391,860 lb
The nozzle load seems very high compared to the 1/8" of thermal growth the pipe will see.
Pipe length = 25'
Pipe OD do= 36"
Pipe ID di= 35.25"
