rcatalina85
- Nov 28, 2011
- 8
I am currently working on a design that involves a pipe bridge and pipe supports, and there is some disagreement on how the friction loads are determined for the supports. This is not a typical senario, as the pipe loop that goes over the bridge serves as a verticle expansion loop. The pipe analysis shows large vertical loads on the two pipe supports adjectent to the bridge (25 kips) whichs is about 3 times the actual pipe weight. So the thermal loading is pushing down on these supports as the loop expands.
My approach was to use a four column braced frame to resist the friction loads, but I am told it looks rediculous and is not typical. I used a friction factor of 0.3 which results in a lateral load of 7.5 kips per pipe (total of 2 pipes). The mechanical engineer did not include any friction in their pipe analysis but I took it upon myself to add it into the support design since it will be steel on steel. I mentioned using different materials for the slide supports, and they are concerned that they will not last and do not want to rely on them.
I have not dealt with vertical pipe loads of this magnitude and maybe I am missing something here....I would appreciate some input.
