Pipe supports
suren12564
30
What are the lugs with respect to pipe supports? What is a shear lug
Can also be a vertical stub of metal welded to the underside of a pipe support, extending into a recess in a concrete foundation to transmit lateral forces to the foundation that anchor bolt shear is unsuited for. It may or may not have an air gap to the concrete to allow some movement.
