Hello, a steel insulated pipeline will operate with a liquid stream to be maintained at aprox 140°C and ambient temperature is aprox 15°C minimum, is there a rule of thumb that determines whether this pipeline cannot be buried/under-ground, and that it has to be above ground? I am thinking that there would be problems with mechanical stress from expanding/contracting, so it needs to be above-ground? Thanks in advance.
