Hi Gents,
Suppose I have an Underground oil pipeline which is anchored (with an anchor block) just before coming out of the soil. The Above-ground portion is directly connected to a "pig receiver" which I am told has a fixed saddle.
I am not comfortable with this arrangement because the portion of the pipe restrained between the pig receiver at one end and Underground Anchor block at the other end will exert extremely large loads on the pig receiver/fixed saddle and on the Anchor block when undergoing thermal expansion (suppose at Start Up when exposed to solar radiation in summer time). I am told by our senior engineers that this pipe arrangement is typical of lines leading to and from pig receivers and pig launchers and I have also seen corresponding schematics showing this pipe arrangement in older oil pipe line design books.
Anyhow, the Anchor block can always be designed for larger loads; my main concern is the internal axial load developed in the pipe itself which is eventually exerted on the pig receiver and its fixed saddle.
Please, note that the segment of the pipe between the two abovementioned points has a longitudinal profile the shape of a skewed or horizontally stretched "S" (no fittings, elbows, and reducers used; the pipe is bent).
Can't really play with making the above ground piping more flexible either because adding loops will translate into using elbows which will interfere with the pig travelling inside the pipe.
I hope I got my point across.
Any Ideas? Apparently this layout has worked before but when actually doing the calculations to find out what the loads on the pig receiver are like, I end up with very large loads (on the order of 30 metric-tons axial load).
Any input on this topic is highly appreciated.
C
C
