Piping Material for CO2 -60¦F
LuisF83
19
Hi:
I want to select material piping for CO2 service -60°F@100 psig, liquid. Searchig some information, I found in "Pressure Vessel Handbook" from Megyesy a table, with Chemical Resistance of Metals. With a recomendation that CS is "fair" for use in CO2 (dry) & "Caution" with CO2 (wet). This recommendation means that I have to use a corrosion admisible thickness greater than 1/8" for example or, in othe hand it´s better to use another alloy, like Inconel or Monel.
The proble to use this alloys is the price and long delivery time. I prefer to use another alloy like A333 Gr 3 or Gr 6.
Maybe do you have some recommendation for this application.
B. Regards,
Luis Felipe
Dear syedfarhanali
Thanks for your help. Now I have a better idea about selection of material, now I have another question, how about other super alloys, like Inconel or Monel? This page doesn´t have info about them.
B. Regards,
Luis Felipe
You can use them if you want to pay 5 to 8 times more. CO2 pipelines use CS, BUT you need to investigate the temperature issue. CS, I believe, is NOT going to be suitable to -60. Check into that in depth.
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
We designed gas processing pipe systems using A-333 Gr 6 piping impact tested to -60F. Welded it with 1% Ni alloy weld filler metals. A-333 grades 3 and 4 can also be used.
I agree. A-333 is probably what you should be using at that temperature.
Dear Luis,
I agree with BigInch, that the price is more, even then I googled and found CO2(Dry) is having excellent comparability with the Monel.
Farhan
Admin
EngineerPK.ORG
Web Portal for Pakistani Engineers Worldwide
Thanks every body
I am going to use A333 Gr 9 or Gr 9 for CO2 -60F. Now I have one more question about welding, hardness test, heat treatment after welding.
Somebody can help or some guidelines about it.
B regards.
Luis Felipe
Dear Luis,
Be specific to your question that will be easy for us to reply.
Farhan
Admin
EngineerPK.ORG
