When calculating minimum thickness for a pipeline using ASME 31.3 equations and values I come up with a value that is too small for wall thickness (~0.002") because of small internal pressure (150psig). Is there an absolute minimum thickness requirement, which says if you calculate a value smaller than this - use this value?
I am using ASTM A106 Grade B Sch 80 carbon steel seamless with a diameter of 1/2".
Thanks in advance.
Thanks in advance.
