piping Vs tubing 1
discla
Which is the difference between piping and tubing ?
Here's a page that describes fire tube boilers:
The name firetube is very descriptive. The fire, or hot flue gases from the burner, is channeled through tubes that are surrounded by the fluid to be heated. The body of the boiler is the pressure vessel and contains the fluid. In most cases this fluid is water that will be circulated for heating purposes or converted to steam for process use.
Every set of tubes that the flue gas travels through, before it makes a turn, is considered a "pass". So a three-pass boiler will have three sets of tubes with the stack outlet located on the rear of the boiler. A 4-pass will have four sets and the stack outlet at the front.
