sgoel
Chemical
- Sep 17, 2000
- 32
We are facing a repetitive failure of a piston in a recip compressor handelling propane-butane rich gas. One of the deviation from design is suction pressure, which is running at 2.1 bar G against design value of 1.4 bar G. On the other hand, discharge pressure is lower at 7 bar g , against design value of 8.0 bar g.
I would like to know whether these changes can cause failure of piston. What are the other causes for failure of pistons in recip compressors?
Thanking you in anticipation please.
S Goel
S Goel
