HarleyE30
Automotive
- Apr 19, 2012
- 31
Hi everyone,
Attached is an image of an initial piston design (bosses are huge so I can initially see where material can be removed). Also please ignore the irregular shape of the piston, it's not for a normal application!
The FEA is simulating the loading in the upwards direction (piston is upside down in image), which would be produced by the gudgeon pin, reacting to the gas force in the cylinder (80 Bar ). The load is applied as a bearing load in the appropriate direction
As you can see, the major stress area is the edge of the pin bore. This piston is aluminium (modelled as AL 6061). Max stress at this point is 101 MPa. Would this be a concern? Is the mesh too large perhaps?
Any advice appreciated, thanks.
