A specification for control valves on water pipes (600mm to 800mm dia) working to control flow into a tank with up to 100m upstream pressure (cavitating conditions) calls for "Piston Type Valves" (this refers to valve type not the actuator type). What is a "Piston Type Valve" ?
For this application I would expect to use a ported sleeve valve with anti cavitation gage.
