A recent ultra-sonic inspection determined several clusters of pitting in a carbon steel storage tank. Tank holds approx. 200,000 gallons of liquid waste containing organic compounds in water. pH is 11-12, but composition is likely to contain chlorides(to be verified).
The operating company has recommended the tank can still be used at a lower volume to accommodate reduced wall thickness measured in the pitting areas. Also, they have applied a corrosion rate (mpy)to estimate useable life based on the rate of material removal in the pitted areas.
Am I right to be concerned with the logic of applying a general corrosion rate to a pitting problem? What options are there to either monitor pitting, or repair the areas? Tank is only needed for about 1 more year.
