place copy of mass field to file properties
alpar79
Industrial
Mar 14, 2011
14
For solidedge v.20 (for st3 is the same) how can you make a customization so that a copy of the mass field in a solidedge part file (.psm, .prt) found at inspect- physical properties – mass to be available automatically updated in file- file properties – custom in a custom field called mass?
I think one of the problems could be in using pdmworks.
Surely that's intended for SolidWorks not Solid Edge, and if it doesn't do what you want it to you should contact the people who sold it to you.
Can't you use the free SolidEdge viewer?
Can't pdmworks handle pdf files?
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
I need the mass becouse i need to transfer it automatically to the erp system.
