Qwikone
- Jul 11, 2008
- 10
I have an existing wall with concrete footer/foundation at 30" deep. I need to place a column supporting a girder truss adjacent to the existing foundation, the problem is that I need to get the column as close to the wall (6"-12") as possible. The existing footer is 24" wide with 8" block in the center. The column footing requires a 30" width. I looked at an eccentric condition and the placement of the column on the end of the new footing but I'm concerned the loading will impinge on the existing footing. I also looked at step pouring the new foundation over a portion of the existing to obtain the 6"-12" distance........
Anyone have experience or suggestions with this?
