HoustonMechEngr
What is the ideal procedure to add barrier fluid to a plan 53A seal reservoir? If the system is pressurized under a nitrogen blanket, how do you go about adding barrier fluid if the leak is at an extremely low rate and you need to add makeup fluid?
I've heard about re-fill carts, but are they able to pump up against the nitrogen pressure? I would htink you would NEVER want to de-pressurize the system as you can see ao-ring shift on the primary seal and possibly never reseat. Thoughts?
