Looking at a low grade clean room (ie less than Grade D, Class 100,000), for tablet forming. Air conditioning is only filtered to EU9. However, client has specified the use of Clean steam for humidification, generated from purified water supply.
Bearing in mind that the rh required is only 37% the humidity load is minimal especially since the system is approx. 80% recirc. Also, the 20% fresh air will contain contaminants which won't be removed by an EU9 filter. It seems to me that use of clean steam is over the top unless anybody can advise particular problems with injecting plant steam into the air stream.
Any advice gratefully received. Thanks.
