In a southern California backyard have two foot high mortared concrete block retaining walls with footer built 15 years ago with the goal of using them as planters but were never planted or irrigated. They are in two tiers of 50 feet long divided by steps so that there are two beds that are 30 feet long and two that are 20 feet long. Irrigation lines and connecting drain outlet was dug in about 6 years ago. The bed widths are each 3 feet wide. The lower beds are flat and upper beds have a small slope which connects to neighbors backyard. Soil in beds seems to be a loam. This area of California gets at most about 20 inches of rainfall a year and there is no groundwater/water table anywhere near the surface. The walls still look good with only some mortar missing and some efflorescence.
Now homeowner wants to plant fruiting and flowering trees, shrubs, perennials and annuals. Irrigation plan is to have drip with occasional deep watering with hose as needed. The soils were dug out to see what the drainage system was like. The french drain was sitting on top of footer with no slope or the wrong slope toward drain but did have gravel and fabric. There was only one drain outlet for the two walls of 50 ft run.
So the question is: In order to have plants like this it seems to be at cross purposes with retaining wall integrity or longevity. The plants need a good rooting depth (preferably 18 inches or more), and soil that drains well but also has good soil moisture holding capacity.
Or is there some compromise for all of this that might work? I have thought about putting the bigger trees in containers, and having plants with non-invasive or shallow rooting depths, making sure soil texture is right in terms of moisture holding capacity and drainage (need help with this also), and toying with lower drain depth and depth of gravel and an extra drain outlet to get slope (but can't go too deep on lower tier because of limited slope in backyard). I wish the walls were taller and wider, but right now this is what I have to work with.
There are just so many variables so going a little crazy.
Will be re-waterproofing the backs of the walls but am still puzzling over the french drain/gravel/compaction/outlet variable, and of course how to make it all work together. Any ideas would be most welcome.
Thank you.
Thank you.
