PW2006
- Aug 22, 2006
- 25
We are going to install several flat bottom carbon steel tanks (approx. 15 ft diameter) on a big concrete slab at a outdoor environment. The liquid stored in the tanks is not corrosive. The tank bottom (exterior) has been painted already. I wonder:
(1) if there is need to put a layer of plastic liner on the top surface of the concrete slab under the tank bottom. Would this provide extra help on reducing the corrosion? If we do need, what is the material and thickness that are normally used?
(2) if there is need to seal the tank bottom edge on the concrete? This will help to prevent (or at least reducing) rain water from leaking into the space under the tank bottom. If it can help too, what is the sealant that is normally used at this application?
Thanks.
Thanks.
