I have an issue with my plastic part; please help.
A small metal ring assembles with plastic parts by a flat-head screw. When rotating and pulling the metal handle by hand over time, one of the plastic parts directly assembled with the metal ring cracked.
Is the flat head screw causing the crack as the force will focus on the angle when rotating? How can I fix this issue? If I change to use a rounded screw head, does it help? Thank you in advance for your help!
