bangerjoe
Industrial
- Oct 16, 2013
- 35
Bit of an oddball one. I would like some advice if possible.
Client has a sheave block which supports rope over a 90 degree bend. (see below)
They're taking the sheave out for servicing and don't want it to bend over a sharp radius (fair enough) and have asked for a length of plastic pipe to be used to support the ropes.
i have checked and the pipe is adequate in terms of min. radius for the rope.
although not heavily loaded (self weight of pipe only - tension is removed), how would one check the pipe for crushing?
i do have mechanical specifications of the pipe, i.e. tensile modulus, poisson's, and yeild stress.
i can work out the resolute force being applied, but have never come accross checking a pipe for local damage like this (traditionally treated them as a member or subject to hoop stress).
Regards, Joe
Regards, Joe
