Hello, I am new to this form stuff so here we go.......
I am looking for a better sizing interference fit
for a plastic called 'gs nylontron'.
We are pressing this sleeve 3.500" long by 1.040" O.D. w/.960" I.D. into a steel tube that is reamed out to a 1.027" - 1.030" I.D.. The sleeve is put around a
steel shaft that is .880" O.D. with a hard plastic end cap. This is put into the steel tube that is reamed out. We press the sleeve with a 12-ton press machine.
The problem we are having is that we push the sleeve in about 2.750" to 3.000" in the tube in length. Then it stops and the end cap start to mushroom the rest of the material outside the tube. Sometimes we can push it in with out a problem. But if it mushrooms out the material....well we got @^&2???[] problems.
I feel the O.D. of the sleeve is way to big and my boss says no. I feel if we had a 1.034" O.D. & .920 I.D. would be better.
The sleeve is only use as a guide for the shaft and stop the bearing asm. at the end of the shaft, (inside the tube), from coming out.
?? what sizes should we be designing for so we can press we ease and not come out of the tube.
Michael.
Michael.
