wadavis
- Jan 14, 2013
- 60
I'm working on a design following the letter of the code with the authority having jurisdiction (National Building Code of Canada, CAN/CSA S16), but I'm not finding references for using plastic torsional resistance. In this case an HSS square tubing is primarily loaded in torsion and I want to calculate the torsion capacity with a fully yielded cross-section, much like the plastic bending resistance of a class 1 beam.
To cut to the chase:
1. Are there any references to torsional resistance in S16 other than 14.10?
2. More importantly, are there any allowances to use the plastic capacity instead of the elastic capacity for torsion in Canadian or other design codes?
Thanks for the help,
Wadavis
E.I.T.
2.1. Any material explaining why it is a bad idea to calculate the torsion resistance of an HSS by the fully yielded cross section?
Wadavis
E.I.T.
