Yobbo
- Apr 22, 2003
- 85
L.S.,
We are in the district heating business. The medium is conditioned water. We apply heat exchangers between the primary and the secondary circuit. Primary circuit contains pressurised water of maximal 150 Celcius; whereas the secondary circuit contains hot water of maximum 90 C. The pressure class is PN40 ( DIN system ).
The traditional setup was to utilise Shell Tube Heatexchangers. The transfer of plate heat exchangers is more efficient than that of a shell tube exchanger. We do have some negative experiences with plate heat exchangers due to problems with leaking gaskets. Is there any objective evaluation about where and when to apply a plate heat exchanger instead of a shell tube heat exchanger? We think that Shell Tube heat exchangers do have the important advantage of internal accessibility, so that cleaning and inspections can be carried out more easily. Even one leaking pipe can be closed and the process can carry on. A leaking plate heat exchanger needs to be opened completely in order to repair the leaking gasket. So we think that repair time and reliability are more favourable with a shell tube heat exchanger. On the other hand we don't have extended experience with plate heat exchangers in order to be able to make an objective comparison. Do you have a suggestion for me, as where to find a reliable comparison between the two types of heat exchangers?
Karel Postulart, The Netherlands
Nuon Power Generation
