Hi all,
I am design a platform which will have grating supported on two I-beams which are then connected to columns etc. I will be using either steel grating or FRP from Webforge (this stuff is pretty standard in Australia). Selecting the grating is easy - the manufacturer has load tables and you select from there.
I am sizing the I-beams to support the grating. If I apply a live loading of 2.5kPa onto the grating, what are the loadings applied to the I beams?
Do I simply determine the area of the grating (load bar area) and then determine the total force from the 2.5kPa loading? This would then be equally distributed between the two I-beams. I can then apply a point load on each I-beam to size it etc.
I haven't used AS1170 standards a lot but they mention tributary area and I am wondering whether I need to know more about this or whether it's more specific to buildings with floors and multiple columns.
What's the correct way of determining the reactions from platform Grating onto supports?
PS. My structural engineer is certifying this design so calculations will be checked. I'm just trying to learn and get it in the ballpark.
Cheers all
Cheers all
