AndrewKo
- Apr 21, 2020
- 2
Hi, I'm working a project that uses a platinum cure silicone impregnated with iron powder that is overmolded onto a steel plate. the material interacts with microwaves heating the silicone and metal plate in order to reach temperatures of 450°F (232°C). We've made some prototypes and are finding that the silicone is emitting some kind of smoke when seeing these temperatures for just a minute or so.
The part in question is pictured for better understanding. The silicone is only .09" Thick and about 8" round
We are compression molding this at 330°F(165°C) for 4 minutes with a 400°F (200°C) post cure for 4 hours.
With just a quick inspection the parts seems to have cured fully with no bubbling or any obvious problems.
I'm wondering what may be causing this smoke to occur.
The material cant handle these temps?
The cure cycle needs to be longer or hotter?
The post cure cycle needs to be longer or hotter?
We are very new at molding silicone and this seems like a odd application. Any help would be much appreciated.
