Hi everyone,
Can someone tell me if there is a way to use a PLC+HMI in a NEMA 7 enclosure (explosion-proof enclosure)?
Hazardous Location is Class I, Division 2, Group D.
I have read many posts but not sure they usually suggest using a purge system which is not my case since I don't have the possibility to provide purged air to the enclosure.
Also, I have also read that "a window kit with interfacing pushbuttons could be used but HMI shall be able to use a PLC register for the screen selector. But not all HMI has the ability to reference a pointer register within the PLC for screen navigation and that is to be taken into account when selecting PLC/HMI brands."
Although I understood the main point I am not very familiar with this solution. If that is possible, how is a window kit with interfacing pushbutton? I could not find anything about that.
Also, I need to use Allen Bradley Compact Logix PLC with the 7" Panel view from Allen Bradley as well.
However, I don't know if Allen Bradley HMI has the ability to reference the pointer register mentioned before.
If any other method available, I would be happy to read any possible suggestions.
