itsmoked
- Feb 18, 2005
- 19,114
Mucking about in this forum, I've been reading the threads pertaining to state machines trapped and forced to live out their existence on Ladder Logic platforms.
Why? Because I'm working on a big(for me) PLC job that I've come to realize should be done as a SM.
Here is a statement I think makes a lot of sense.
How is this implemented? Is it just a single output rung with a slew of parallel 'state number' contacts?
Where do You put this output statement? In an "outputs area" or perhaps after the last state that would apply?
Keith Cress
kcress -
I believe that every step in a process should have a state. That way you can have a simple single point for outputs: A solenoid is on in states 3 to 5 and state 7. The solenoid operation is clearly defined in a single rung and there are no surprises when you go back to modify the solenoid operation.
Keith Cress
kcress -
