gb12345
- Mar 26, 2018
- 9
Hi, This is for learning purposes but i am using a real life situation that I have came across before.
If someone could please show me the steps/explanation of this I WOULD GREATLY APPRECIATE it.
So, there is a vessel sitting on a beam. The vessel weighs 240kip. The vessel is being jacked up with jacking cans. Half of the vessel weight is on one beam and 2 jack cans and other half of the weight is on the other beam and 2 jacking cans. So, we are only looking at 1 beam and 2 jacking cans with half of the weight (120 kip). Beam weight is 1,300 lbs (not too sure if this weight matters). 3'11" of the vessel/saddle is sitting on the beam.
A visual image of what is happening is below:
** What I am looking for: How to run this exact situation (or a similar situation) in RISA 3D with explanation and steps. I realize the beams will most likely break or be very close to it. But i want to know what are the steps in Risa 3d and explanation to get to the solution: Can these beams take this weight when the Jacking cans are pushing the beam and vessel up?
The risa file for the beam is below. Load has not been added to the beam or jacking cans.
THANK YOU VERY MUCH
THANK YOU VERY MUCH
