Here is my question. I'm looking at my screen and i see a plan view of a Building and it's sides measure 300', using the distance command. But i'm drawing the sewer line to service that building. and i need to draw a line exactly 24'. and when i use the line command, i pick my starting point and when i put 24' in it says point or option keyword required. ( i put in both 24' and @ 24,0) and it still gives me that message. And then i tried to use pline, and typed in ( w/o snaps on) the same as above it gives me a line longer than the side of the building which measured 300'. Any suggestions?
Juice
Juice
