plot file converter 2
CADQUEEN
54
does anyone know of anything that will convert plt files to dxf, dwf...or dwg files?
Try the following web site, " it is Govert's Tools. I don't recall what format it will save the drawing to.
Hope that this helps. Charles S. Parnell
Southern Store Fixtures
Thanks...but it is in GERMAN...:)
Cadqueen:
Use the web page path go to the website and erase the last quote " and try that as your web page path. Should be Charles S. Parnell
CADqueen,
Curious?
Do you have the "Express tools" for AutoCAD 2000i? [neutral]
If so, you could use that ....
Go to ...
Express>file tools>convert plt to dwg.
You didn't mention which version you were on or if you tried this already. But it was worth a shot.
Hope this helps.
Rich [roll1]
What about plt files which are not in HPGL format? I've tried express tools and obviously I didn't obtain any result (in fact, the message of the software was the file is not a HPGL format). Also, with plot command from dos prompter I didn't have any result.
Untill now, I didn't see such kind of files (plt files which are not in HP format).
Any suggestion?
