Ploting variable thickness
n3l3
69
Hi all
I am trying to model a shell with variable thicknes by means of an analytical field.
First of all i dont know if I am doing it properly, (I created a variable analytical field and I assigned it to the thickness of a section)
When I try to plot the thickness of the shell I can see no thickness so...
is this possible?
how could I check that each element gets the proper thickness?
thanks a lot
n3l3
Well, when running th ejob, ii can check with the query tool the thickness of the element, and I can see i have a thickness of one in every element.
(which is wrong in every way)
You can render the shell thickness in the assmebly module, go to View -> Assembly Disply Options -> General, there is a tick box for Render shell thickness.
Thanks bkal,
the problem is that when doing that no thickness apears for the elements with the analytical thickness
Ok, i got the answer, i have to get into the STH variable which is the thickness.
Once that I run the job I get the variable so I can check the thickness.
thanks all
Hi n3l3,
I'm facing the exact same problem.
What do you call STH variable please?
Could you post a screenshot of your parameters so I can get the inspiration please?
Thx
