Plotting to a tiff in Catia V4 ? 1
rickyt
Automotive
Jun 26, 2002
233
Is it possible to plot to a tiff file larger than the screendump size? I Would like something that could be sent out at or near full scale. If this is possible what needs to be done?
Yes you can make tiff files from catia V4 Files using the plot function !
It runs like that :
/ HEADER BLOCK DEFINITION
*BEGIN_HEADER
/ ------------------------------------------- 10 CHARACTERS DEVICE NAME
*NAME TIFF
/ -------------------------------- 45 CHARACTERS PLOTTING PANEL COMMENT
*COM TIFF 200 DPI
*TYP PRINTER
*END_HEADER
/ PARAMETERS BLOCK DEFINITION
*BEGIN_PARAM
/ --------------PLOTTING KEYWORDS (REFER TO CATPUB REFERENCE MANUAL)
*EXPORT TIFF
*RDY 200
*END_PARAM
/ EXECUTION BLOCK DEFINITION
*BEGIN_EXEC
if [ -s $CATOUT ] then
# qprt -P lp0 $CATOUT
cat $CATOUT > $HOME/toprint
else
echo " the file $CATOUT doesn't exist , check your traces"
fi
*END_EXEC
/ RUN-TIME BLOCK DEFINITION
*BEGIN_RTIME
CATOUT=$HOME/catout.tif
export CATOUT
*END_RTIME
The $HOME/toprint is the .tif file in 200 DPI
Stan
I want to save the tiff file to another place than my home directory, and give the tiff file another name than catout. What changes this script needs so it will ask where you want to save the file and also ask the name of the file (like "save as")?
the plot cfg file as described above worked fine, it would generate a tiff file. The only problem I had was that I would never get an execution successful window and some syntax errors in the background window. I edited out a few lines in the Execution Block definition area.I no longer
get the syntax errors and I do get a execution successful window. Plot cfg file looks as such:
*BEGIN_HEADER
*NAME TIFF
*COM TIFF 300 DPI
*TYP PRINTER
*END_HEADER
*BEGIN_PARAM
*EXPORT TIFF
*RDY 300
*END_PARAM
*BEGIN_EXEC
*END_EXEC
*BEGIN_RTIME
export CATOUT
*END_RTIME
