Plug weld
Veer007
379
Hey Guys,
What is the standard diameter of plug weld and spacing between welds, and how can you calculate its strength? CISC or AISC
Thanks in advance!!
For metal deck - usually 1/2” diameter. Capacity depends on gage of the deck.
What are you welding?
Mike McCann, PE, SE (WA, HI)
New door jamb bent plate with ex. CIP plates
Thanks in advance!!
Mike, you're thinking of a spot or puddle weld - not the same thing as a plug weld.
Veer007, check out CSA W59-18 clause 4.4.2.1 - diameter of the plug shall be the thickness of the plate + 8mm. There is a maximum diameter as well, but the standard would be the minimum size. For strength calculations - there is no allowable tension in a plug weld, just shear.
Isn't that "plug" meant to fill the void space, then grind smooth. Otherwise, it will be a spot, or tack weld.
As CanPro notes, a plug weld is only for shear. Thickness of the material times the circumference of the circle is the shear area with no benefit of reinforcement.
