ewelly
- Aug 5, 2009
- 5
Hi, I have a pneumatic logic question. I have an application where I need to have valve X pass air unless one of two limit valves is made. My issue is whatever I come up with dumps line pressure thru the exhaust of 1 limit when the other is made. Thought about a shuttle valve but this will lock up because it can't exhaust.
The application is a stroker with a cutting head. Want the head to turn on when it comes off the LS and stay on until it reaches the LS at the other end then turn off again.
Any suggestions appreciated, air logic isn't something I use very often.
