When producing valve data sheets (Ball, Gate & Globe) and specifying that pressure testing should be in accordance with API 598 and BS 6755 Pt1, I believe I should specify whether a pneumatic seat test is required. Is there a standard that recommends what services a pneumatic seat test is indeed required for? For example, why is it that Gas would require a pneumatic test but plant air wouldn't?
