RobPE
Geotechnical
- Sep 4, 2003
- 50
Is there an advantage to hydraulic vs pneumatic controlled direct shear test machines?
Our labs utilize pneumatic machines, and per ASTM, verbatim, we are out of spec. We have considered converting to hydraulic because of this, but we would we be adding value to the testing with this time consuming and non-trivial project or are we meeting a requirement that does not result in a real benefit to the testing results?
Section 6.4 of ASTM D5607 states that for maintaining the Normal Pressure: “hydraulic component that will hold a pressure, within 1%”.
For shear displacement, Sect 8.6.2.2, no explicit hydraulic requirement(s).Our labs utilize pneumatic machines, and per ASTM, verbatim, we are out of spec. We have considered converting to hydraulic because of this, but we would we be adding value to the testing with this time consuming and non-trivial project or are we meeting a requirement that does not result in a real benefit to the testing results?
