Pocket Penetrometers
Okiryu
1,094
Hi, can you recommend manufacturers for pocket penetrometers? I am in Japan so it need to be shipped here. I am currently using a SOILTEST pocket penetrometer but want to buy a new one as it is getting old...Thanks.
Thanks for your recommendations. I am trying to contact the Taiwan dealer as there is not a dealer for Japan...
Hi, do you use also the Torvane? For field shear strength readings, clients normally give the option to use pocket penetrometers or Torvanes, so just want to compare between these 2 tools.
Looks like a torvane. I guess that geovane is the name you use in NZ for torvanes? Thanks.
BigH, thanks for the clarification. I am not familiar with the torvane so it is good to know it.
