points are invisible in sketch??? 1
loworange88
40
Good Morning! I'm using NX11 and for the first time ever the points do not show up in a sketch. prior to today, all manually added points would show up as a "+" and they could be easily selectable for dimensioning. Today, all manually added points are invisible, all lines and other sketch items are visible, but not points. I can use auto dimension and it will create dimensions to those points, and the hole feature will grab them and make holes on those locations, but they are not visible with the sketch. HAs anyone had this happen before? My sketchs are on work layers, and all layers with objects are visible.
I only have a guess for you. Go into . . .
Preferences > Visualization > Handles/Points tab > Handle/Point size
and check the size of your points.
Jerry J.
UGV5-NX11
Thanks Jerry, I tried that, but it didnt do anything. I gave up and restarted my computer and its fine now. Must have been some sort of glitch.
Thanks, have a great day.
