Polyline: Do you want to make it one? (Y)
uGlay
389
what is the command you use to bypass this question when using the PE command?
thanks.
You can't "bypass" it. It means you have selected a line or arc, which doesn't have all the properties of a pline. If you select a pline, you don't get the question.
In order edit a polyline (which is what Pedit does), you must have a pline to begin with.
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
yeah i know that, but there is a command that bypasses the question and makes it a polyline automatically. i learned it at my last job but now i dont remember what it was...... :(
Set the system variable "Peditaccept" to 1 and it will no longer ask. 2005 and up I think.
that's it. too bad im on 2000! DOH!
You could write a short lisp that would check it the object selected is a line or arc and if it is run the pedit command and anwser yes to the prompt, it it a polyline already, just run the pedit command, and if it's anything else return a error to the command line and reprompt to pick something else.
i have no idea on how to even get close to doing that. :(
