Joe_
- Nov 23, 2020
- 3
I have a wet pond with a permanent pool whose flow will pass through a riser structure and exit via an outlet pipe. The outlet pipe will be connected to a level spreader (see image).
For the purposes of a supplemental calculation, I was assuming that the flow from the pond outlet pipe could only pass through the standpipe/riser portion of the level spreader - not through the perforated pipe. The standpipe/riser (of the level spreader) was assumed to be about 2' high.
A reviewing agency commented and we were asked to "..please prove no backwater at wet pond riser in case of bigger storms.."
Looking at my attached routing diagram, do I have this scenario modeled correctly?
