I used the HydroCAD sizing feature for ponds to get an initial estimate of the pond volume required (using the pre-developed 50-year runoff flowrate). Then I set up my model to reflect the post-developed flow (Subcatchment) routed to the pond and then routed to a Reach (the receiving basin / stream).
The bottom of my pond is at Elev. 186.00 and top is at 192.00. I modeled the outlet structure with 2 - 12" orifices/holes at 186.25; then a V-notch weir starting at elev. 189.00 that is 3.0' wide and 1.5' tall; then a horizontal 4'x4' orifice for outlet structure overflow. The outlet pipe from the riser structure leaving the pond is an 18" RCP starting at elevation 186.00 at 2.56% slope. My current pond volume is 43,029 CF.
I have tried various hole sizes for the orifices and various elevations for the orifices and V-notch weir, but I can't get the 2-year and 25-year events to discharge below the pre-developed rate. Do I just need to keep increasing the pond volume until it works? I am alredy much larger than my initial pond size of 32,000 cf. Is there any tips/tricks for configuration of the outlet structure to get the discharge flowrates less than the pre for the 2, 5, 25 and 50 year events?
"You're only as old as you want to feel."
