Pop test
kkp3456
Petroleum
May 14, 2011
10
I would like to if there is any pop test for Vacuum relief valves. If yes what is the criteria?
Heather, could you recheck the link -- all those "%" signs appear to make it unworkable.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
It is always possible to have or require a certified functional test for any valve, with one or more tests results and certified and/or witnessed certification papers after several valve standards.
I gather however that you really ask if there is some standardized procedures for testing a vacuum valve, and if this is set down in some national/international official standard.
I am not quite sure about this (have you tried google or searched homepages at different producers of safety valves)?
You will, however, even if this is a different constructed device, find standard tests for rupture discs, also valid for vacuum service.
(Try for instance Fike or others)
