  • Congratulations Toost on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
PORE PRESSURE VARIATION IN LOOSE SOIL WITH DEPTH
GAURAV KHANDELWAL
is it possible to get negative pore pressure in loose cohesive soil in CPT test???
It depends on how you define 'loose'. What are the stresses? For that matter, what is 'loose cohesive soil': cohesive soil isn't usually characterised by its density (that's for cohesionless soil).
Whether or not something will contract or dilate depends on what side of the critical state line you are. Generally you wouldn't expect 'loose' soil to dilate, but the stresses and critical state line are the other factors to consider.
yes.
f-d
ípapß gordo ainÆt no madre flaca!
Just as precation, are you installing driven piles? Negative pore water pressures on a CPT is a red flag for pile design. Negative pore water pressures can be indicative of a pile relaxing and losing capacity! Perform a load test after a couple of weeks to ensure the capacity at EOD is maintained.
