Jan 10, 2022 #1 RMTT Structural Jan 10, 2022 1 0 0 TT Any recommendations on AISC design of haunched members?
Jan 10, 2022 #2 chris3eb Structural Jun 26, 2012 144 0 16 US AISC Design Guide 12 covers strengthening existing connections via the addition of haunches. https://www.aisc.org/Design-Guide-1...l-Welded-Moment-Frame-Connections-for-Seismic Upvote 0 Downvote
Jan 10, 2022 #3 dik Structural Apr 13, 2001 25,565 0 36 CA Depending on the size of your portal, there is a spreadsheet by Alex T (sp?) that looks after small portal frames. Rather than think climate change and the corona virus as science, think of it as the wrath of God. Feel any better? -Dik Upvote 0 Downvote
Jan 11, 2022 #4 straub46 Structural Oct 22, 2015 87 0 6 US Might be able to find some good information in AISCs Design Guide 25 as well, Non-Prismatic Member Design. https://www.aisc.org/products/publi...gn-using-nonprismatic-members-second-edition/ Go Bucks! Upvote 0 Downvote
Jan 11, 2022 #5 Spanky7 Structural Jul 14, 2008 25 0 0 US Check out the following 1. AISC Single Span Rigid Frames. https://www.aisc.org/globalassets/a...f-print/single-span-rigid-frames-in-steel.pdf 2. Rigid Frame Formulas by Kleinlogel https://kupdf.net/download/kleinlogel-rigid-frame-formulas_58a67b946454a7cd3fb1e8dd_pdf 3. Frames and Arches - Condensed Solutions for Structural Analysis by Leontovich http://ignca.gov.in/Asi_data/10897.pdf Upvote 0 Downvote
Jan 12, 2022 #6 dik Structural Apr 13, 2001 25,565 0 36 CA Attached... [URL unfurl="true"]https://res.cloudinary.com/engineering-com/raw/upload/v1641967493/tips/FRAME_nxvqkp.xls[/url] [URL unfurl="true"]https://res.cloudinary.com/engineering-com/raw/upload/v1641967494/tips/FRAME_metric_ajyqrq.xls[/url] Rather than think climate change and the corona virus as science, think of it as the wrath of God. Feel any better? -Dik Upvote 0 Downvote
