BadgerPE
- Jan 27, 2010
- 500
Hi all. I am working on a project in which we are designing a large addition to be added to an existing two story building. The new addition will be built in such a fashion that it matches up with the roof line, exterior walls, etc. The wall dividing the new and old portions of the building is currently a shear carrying wall. However, the architect is proposing to remove the first floor wall to create a large open room between the new and old structures. Without any interior walls capable of picking up the shear, it has been decided that the best course of action may be to install a steel moment resisting frame inside the first floor wall opening. My question is, how do you properly model the columns of the frame for the wind loading applied? Do you apply the resultant wind load from the tributary area of the frame to a specific point, or do you model it as a distributed load acting over the full length of the column. Any help would be greatly appreciated!
