ETAP is capable of calculating automatically cable positive, negative and zero sequences impedance. For transformers, Etap can determine the zero sequence based on test data and given connection. Base on motor type, size and connections ETAP has a library that can help with the sequence impedance.
Utility sequence impedance is a hard input data as
