schreibs
- Mar 11, 2015
- 33
OK guys, Here goes again.
I last asked for your help stabilizing the roadbed for the 1/4 mile lane to my planned home across virgin soil. Now, I'm building a simple post and frame shed in the same area as this roadbed, laterally in the same position at the base of a small forested hill. The location is in the same field I referred to in the previous thread.
Here is the problem:
-- building 200 sq ft shed(keeping it small for now) using only 8, 4x6 posts, simple lean to shed but must place the post bases below frost level-- 42" here. The grassy field here drops about 6" per 10 ft. Placement is about 20 yards from a wooded hill, with an expected increase in the rise up.
-- augering the post holes yesterday I did not get far, just the first hole. At about 3 ft I hit mud, looking in, I could see water flowing in, a few minutes later the sides of the hole were caving in! After the dust(ummm, water) settled the water level was only 18" from the top of the hole.
-- I tried again closer to the hill about 30 ft from the first (i.e. uphill slightly, maybe a foot ) and hit water again. So, now, two artesian wells! This one settled out about 3 ft from the top. So, the water table recedes a bit as the land goes uphill. No surprise.
I really want to build this shed to house some equipment over the winter before building the home next spring. Moving up the hill into the forest before the hill rises drastically is a possibility but it some real downsides I do not need to detail just now. However, doing so would likely get to a point above the water table based on auger drills.
I don't want this to be expensive for a simple and small shed. I don't want to get in a big cement truck and wreck my newly fixed lane when I KNOW now that the lane also has a high water table beneath it and was likely the main cause for all the work I put into it. Any ideas how I can place 8 dang posts for this shed without having to place concrete piers or some other costly foundation support?? OR, another way to address this is not to place the posts into the ground but ONTO something(?). . . I have some thoughts on this but will hang fire until I hear your own!
